Frequently Asked Questions
Configuration
Absolutely!
You have two options:
That's simple.
It's essential to have the same unique ICAO hexadecimal code on all your devices. To do so, simply enter it in SafeSky under "Preferences > My Aircraft > Enter your Callsign > Turn on the Transponder button," and the updated code will automatically appear. It's important to remember to configure all your external devices (such as FLARM, PilotAware, SkyEcho, Stratux, etc.) with the same code.
Weather reports (METAR) are available in the PREMIUM plan. They are accessible during your entire flight, indicating for each upcoming destination the weather you can expect.
That's possible.
It is very low. On average, traffic data consumption for one hour of flight is about 2 MB.
o Use the SafeSky filters to only transmit the data you really need
o Plug in a charger
o Foresee an additional external mobile battery
How to unsubscribe?
Compatibility
Yes and No.
Plan PREMIUM required.
  • Android 6 + 2GB RAM minimum
  • Apple iOS 13 minimum
