Frequently Asked Questions
Weather reports (METAR) are available in the PREMIUM plan. They are accessible during your entire flight, indicating for each upcoming destination the weather you can expect.
That's possible.
It is very low. On average, traffic data consumption for one hour of flight is about 2 MB.
o Use the SafeSky filters to only transmit the data you really need
o Plug in a charger
o Foresee an additional external mobile battery
How to unsubscribe?
Compatibility
Yes and No.
Android 6 + 2GB RAM minimum
Apple iOS 13 minimum
