Frequently Asked Questions
Configuration
Absolutely!
You have two options:
See also here
That's simple.
See also here
That's easy.
To set-up a split view, follow the simple steps as explained in Apple’Apple’s and Google’Google’s tutorials on this topic.
See also here
Using EasyVFR
If you're using EasyVFR, you probably forgot to add your callsign to EasyVFR configuration as described on this link.
Functioning
  • In Europe, the internet coverage is generally good and SafeSky has a success rate of 86% for data transmission up to 5,000 feet. There may be spots with no coverage, but SafeSky will reconnect automatically once the connection is restored.
  • SafeSky's community is mostly pilots flying in E and G airspace classes up to 5,000 feet AGL. Above that, pilots usually fly in a different airspace.
SafeSky collects and displays traffic data from almost 20 different protocols, including ADS-B, FLARM, OGN, and partially Mode S. While it may not show everything, it offers significantly more traffic information than a single system (even more than popular systems like Flightradar24) or no system at all, without any extra hardware or financial cost. Using SafeSky can give you at least "20 times more" traffic information, including exceptional traffic such as paramotor traffic. Of course, if other pilots aren’aren’t using any detection device, SafeSky, like any other system, will not be able to see them. It’It’s like driving a car: if you do not turn on your headlights at night you cannot be seen …… or too late.
SafeSky is a tool designed to create harmony in the sky for all users, including paragliders who are the most vulnerable users due to the slow speed and closeness with fast aircraft like ULMs and GA planes. With SafeSky, this potential collision risktyou can beimprove mitigatedsafety  simply by having your phone in your pocket. As a paramotor or paragliding pilot, you can receive alerts about surrounding fast aircraft. Additionally, SafeSky integrates traffic information from various sources, including dedicated apps like Gaggle, eVario, and XCTrack, as well as external devices such as SkyTraxx and Air3. By sharing in-flight positions through SafeSky's collaborative platform, paragliders, paramotor pilots and GA pilots can receive respective SafeSky traffic alerts and fly safely in harmony.alerts.
With over 50,000 pilot-users in our community, there is a good chance that your fellow pilots are using SafeSky. However, even if they would not be using it, there is definitely added-value for you. SafeSky collects traffic data from close to 20 other sources besides SafeSky, so we –– and thus you as well when using SafeSky - can still see other aircraft even if they are not using SafeSky and alert them about potential traffic conflicts.
And …… don’don’t hesitate to invite your fellow pilots to use SafeSky!
SafeSky is in close contact with the market’market’s major stakeholders in order to aggregate these data. In any case, as pilots, we would always recommend considering an ADSB-out solution as well, since today Mode S requires multilateration (more than 4 ground-based stations to be detected).
That's possible.
It is very low.
In comparisons, it’it’s using similar power as Waze or Coyote in your car.
  • Plug in a charger
How to unsubscribe?
Why is this beneficial?
How to set it up?
  1. Open the browser on your computer or SmartTV.
  2. Navigate to SafeSky Live Traffic. (https://live.safesky.app)
  3. Zoom into your airfield’airfield’s location. The system will remember this setting for future access.
  4. Customise your view by filtering for specific traffic altitudes, changing the map theme, and more.
Sharing Premium Licenses Between EasyVFR and SafeSky
EasyVFR to Safesky
To transfer your EasyVFR Premium license to SafeSky, follow the simple steps described on this link.
SafeSky to EasyVFR
1. Go to Traffic Sharing from the SafeSky app menu.
2. Be sure Enable Traffic Sharing is enabled.
3. Tap on the select app line.
4. Select EasyVFR.
5. Tap on Connect with EasyVFR.
Issue
Solution
  1. Check your device's time settings:
    • On iOS, go to Settings > General > Date & Time.
    • On Android, go to Settings > System > Date and time.
  2. Enable automatic time setting:
    • Ensure Set Automatically is turned on. If it is already on, toggle it off and then back on to resynchronize your device's time with the network.
  3. Verify the accuracy of the time:
    • Compare your device's time with other devices to ensure it is correct.
Compatibility
Yes and No.
Yes, SafeSky sends traffic via GDL 90 to SD VFR. This is however only possible on Android and not iOS due to SD VFR’VFR’s internal decision not (yet) to develop GDL 90 on iOS. If you have any questions on this subject, please contact SD VFR.
Plan PREMIUM feature.
  • Android 6 + 2GB RAM minimum
  • Apple iOS 13 minimum
See also here
