Frequently Asked Questions
Configuration
Absolutely!
You have two options:
That's simple.
That's easy.
Functioning
In Europe, the internet coverage is generally good and SafeSky has a success rate of 86% for data transmission up to 5,000 feet. There may be spots with no coverage, but SafeSky will reconnect automatically once the connection is restored.
SafeSky's community is mostly pilots flying in E and G airspace classes up to 5,000 feet AGL. Above that, pilots usually fly in a different airspace.
That's possible.
It is very low.
- Plug in a
chargercharger - Foresee an additional external mobile battery
How to unsubscribe?
Why is this beneficial?
How to set it up?
Issue
Solution
Check your device's time settings:
Enable automatic time setting:
Verify the accuracy of the time:
Compatibility
Yes and No.
Android 6 + 2GB RAM minimum
Apple iOS 13 minimum
