Frequently Asked Questions
Configuration
Absolutely!
You have two options:
That's simple.
That's easy.
Functioning
In Europe, the internet coverage is generally good and SafeSky has a success rate of 86% for data transmission up to 5,000 feet. There may be spots with no coverage, but SafeSky will reconnect automatically once the connection is restored.
SafeSky's community is mostly pilots flying in E and G airspace classes up to 5,000 feet AGL. Above that, pilots usually fly in a different airspace.
That's possible.
It is very low.
- Plug in a charger
How to unsubscribe?
Why is this beneficial?
How to set it up?
- Open the browser on your computer or SmartTV.
- Navigate to SafeSky Live Traffic. (https://live.safesky.app)
- Zoom into your airfield’s location. The system will remember this setting for future access.
- Customise your view by filtering for specific traffic altitudes, changing the map theme, and more.
Issue
Solution
Check your device's time settings:
- On iOS, go to Settings > General > Date & Time.
- On Android, go to Settings > System > Date and time.
Enable automatic time setting:
- Ensure Set Automatically is turned on. If it is already on, toggle it off and then back on to resynchronize your device's time with the network.
Verify the accuracy of the time:
- Compare your device's time with other devices to ensure it is correct.
Compatibility
Yes and No.
Android 6 + 2GB RAM minimum
Apple iOS 13 minimum
