Frequently Asked Questions
Configuration
Absolutely!
You have two options:
See also here
That's simple.
See also here
That's easy.
See also here
To activate the 'Approach' mode, simply go to 'Settings  > Maps > Manage countries' and download the countries you want to activate.
LINK TO MANUAL
Functioning
  • In Europe, the internet coverage is generally good and SafeSky has a success rate of 86% for data transmission up to 5,000 feet. There may be spots with no coverage, but SafeSky will reconnect automatically once the connection is restored.
  • SafeSky's community is mostly pilots flying in E and G airspace classes up to 5,000 feet AGL. Above that, pilots usually fly in a different airspace.
That's possible.
It is very low.
  • Plug in a charger
How to unsubscribe?
Compatibility
Yes and No.
Plan PREMIUM feature.
  • Android 6 + 2GB RAM minimum
  • Apple iOS 13 minimum
See also here
