Frequently Asked Questions
Configuration
Absolutely!
You have two options:
LINK TO MANUAL
That's simple.
LINK TO MANUAL
That's easy.
LINK TO MANUAL
To activate the 'Approach' mode, simply go to 'Settings >Maps > Manage countries' and download the countries you want to activate.
LINK TO MANUAL
Functioning
In Europe, the internet coverage is generally good and SafeSky has a success rate of 86% for data transmission up to 5,000 feet. There may be spots with no coverage, but SafeSky will reconnect automatically once the connection is restored.
SafeSky's community is mostly pilots flying in E and G airspace classes up to 5,000 feet AGL. Above that, pilots usually fly in a different airspace.
SafeSky will provide you with traffic information even if your pilotfellow friendspilots do not use SafeSky.
That's possible.
It is very low.
- Plug in a charger
How to unsubscribe?
Compatibility
Yes and No.
LINK TO MANUAL
Android 6 + 2GB RAM minimum
Apple iOS 13 minimum
LINK TO MANUAL
