IOS Devices
iOS 13 and above Instructions
Android Devices
On Android > 11, it should be working out of the box. Android should detect that no internet connection is available on the WiFi, and prompt you to use your SIM data instead.
Recent versions of Android OS also allow users to force the OS to always use Mobile Data. This is not as ideal as the iOS settings above, so only use as a last resort. You must toggle this setting whenever you DO want to use a WiFi Internet Connection.
Enable Developer Mode
Toggle Mobile Data Setting
The Stratux team has made a specific workaround if none of the above is working.
Other cases
If none of the above scenario is working, the combination between your phone manufacturer, operating system version and the extra software layer of your vendor is going to make things specific.
