Advisory UAV operations
The SafeSky API provides features to push the publication of active UAV activity areas, when no live telemetry is available.
Endpoint: POST /v1/advisory
Description: Publish one or more UAV active activity areas to the SafeSky platform. When an area is not active any more, simply stop pushing it. The POST frequency for advisory messages should one minute.
  • x-api-key: <your_api_key>
Example 1: Publishing a Polygon Advisory
GeoJSON Example:
        "id": "Advisory123",
        "call_sign": "UAV_Alpha",
        "last_update": 1738142598,
        "max_altitude": 150,
        "remarks": "Surveying area"
        "coordinates": [
            [4.39201, 50.69378],
            [4.39300, 50.69400],
            [4.39400, 50.69500],
            [4.39201, 50.69378]
Example 2: Publishing a Point Advisory with a Radius
Instead of a polygon, a point can be used to represent a UAV operation with a maximum radius max_distance.
GeoJSON Example:
        "id": "my_advisory_id2",
        "max_distance": 500,
        "remarks": "Inspection rails"
        "type": "Point",
        "coordinates": [
          4.4,
          50.7
Example 3: Publishing Multiple Advisories Simultaneously
  • A polygon-based advisory representing an inspection area.
  • A point-based advisory with a specified radius.
        "id": "my_advisory_id1",
        "max_altitude": 111,
        "last_update": 1738142590,
        "coordinates": [
            [4.39201, 50.69378]
        "type": "Point",
        "coordinates": [
          4.4,
          50.7
id string Yes A unique identifier for the advisory message. This helps in tracking and managing advisories.
call_sign string No The call sign associated with the UAV operation. It can be used for easy identification.
last_update long Yes The timestamp of the last update in seconds since epoch (UTC-0), ensuring the advisory's relevance..
max_altitude int Yes The maximum altitude (in meters AMSL) atfor which UAV operations are expected to take place.operations.
remarks string No Free text comments providing additional information about the advisory (e.g., purpose of operation).info.
max_distance int Yes (for Point) The radius (in meters) definingfor thepoint-based UAV operation area when using a point advisory.advisories.
  • 201 Created: Advisory information published successfully.
  • 400 Bad Request: Invalid parameters or failed authentication.
Notes:
  • Ensure that the coordinates for a polygon form a closed loop by repeating the first coordinate at the end of the array.
  • When using a point, the max_distance property is required to define the radius of operation.
