Advisory UAV operations
The SafeSky API provides features to push the publication of active UAV activity areas, when no live telemetry is available.
Endpoint: POST /v1/advisory
Description: Publish one or more UAV active activity areas to the SafeSky platform. When an area is not active any more, simply stop pushing it. The POST frequency for advisory messages should one minute.
1.1Example 1: Publishing a Polygon Advisory
GeoJSON Example:
"id": "Advisory123",
"call_sign": "UAV_Alpha",
"last_update": 1738142598,
"max_altitude": 150,
"remarks": "Surveying area"
"coordinates": [
[4.39201, 50.69378],
[4.39300, 50.69400],
[4.39400, 50.69500],
[4.39201, 50.69378]
1.2Example 2: Publishing a Point Advisory with a Radius
Instead of a polygon, a point can be used to represent a UAV operation with a maximum radius max_distance.
GeoJSON Example:
"id": "my_advisory_id2",
"max_distance": 500,
"remarks": "Inspection rails"
"type": "Point",
"coordinates": [
4.4,
50.7
1.3Example 3: Publishing Multiple Advisories Simultaneously
"id": "my_advisory_id1",
"max_altitude": 111,
"coordinates": [
[4.39201, 50.69378]
"type": "Point",
"coordinates": [
4.4,
50.7
call_sign |
max_altitude |
remarks |
max_distance |
Notes:
- Ensure that the
