Advisory UAV operations
Endpoint: POST /v1/advisory
GeoJSON Example:
        "id": "Advisory123",
        "call_sign": "UAV_Alpha",
        "last_update": 1738142598,
        "max_altitude": 150,
        "remarks": "Surveying area"
        "coordinates": [
            [4.39201, 50.69378],
            [4.39300, 50.69400],
            [4.39400, 50.69500],
            [4.39201, 50.69378]
Instead of a polygon, a point can be used to represent a UAV operation with a maximum radius max_distance.
GeoJSON Example:
        "id": "my_advisory_id2",
        "max_distance": 500,
        "remarks": "Inspection rails"
        "type": "Point",
        "coordinates": [
          4.4,
          50.7
        "id": "my_advisory_id1",
        "max_altitude": 111,
        "coordinates": [
            [4.39201, 50.69378]
        "type": "Point",
        "coordinates": [
          4.4,
          50.7
call_sign |
max_altitude |
remarks |
max_distance |
Notes:
- Ensure that the
