Advisory UAV operations
Endpoint: POST /v1/advisory
Content-Type
:application/json
x-api-key
:<your_api_key>
GeoJSON Example:
"id": "Advisory123",
"call_sign": "UAV_Alpha",
"last_update": 1738142598,
"max_altitude": 150,
"remarks": "Surveying area"
"coordinates": [
[4.39201, 50.69378],
[4.39300, 50.69400],
[4.39400, 50.69500],
[4.39201, 50.69378]
GeoJSON Example:
"id": "my_advisory_id2",
"max_distance": 500,
"remarks": "Inspection rails"
"type": "Point",
"coordinates": [
4.4,
50.7
You can submit multiple advisories in a single request by including multiple features within the FeatureCollection
. These features can be a mix of points (with a defined radius) and polygons, depending on how the advisory areas are represented. This approach allows efficient submission of multiple UAV advisories in a batch format instead of individual POST.
"id": "my_advisory_id1",
"max_altitude": 111,
"coordinates": [
[4.39201, 50.69378]
"type": "Point",
"coordinates": [
4.4,
50.7
Parameter | Type | Required | Description |
call_sign |
max_altitude |
remarks |
max_distance |
Notes:
- Ensure that the
coordinates
for a polygon form a closed loop by repeating the first coordinate at the end of the array. - When using a point, the
max_distance
property is required to define the radius of operation.
