Advisory UAV operations
Publish Advisory Information
Endpoint: POST /v1/advisory
Publishing a Polygon Advisory
GeoJSON Example:
"id": "Advisory123",
"call_sign": "UAV_Alpha",
"last_update": 1738142598,
"max_altitude": 150,
"remarks": "Surveying area"
"coordinates": [
[4.39201, 50.69378],
[4.39300, 50.69400],
[4.39400, 50.69500],
[4.39201, 50.69378]
Publishing a Point Advisory with a Radius
GeoJSON Example:
"id": "my_advisory_id2",
"max_distance": 500,
"remarks": "Inspection rails"
"type": "Point",
"coordinates": [
4.4,
50.7
Publishing Multiple Advisories Simultaneously
"id": "my_advisory_id1",
"max_altitude": 111,
"coordinates": [
[4.39201, 50.69378]
"type": "Point",
"coordinates": [
4.4,
50.7
call_sign |
max_altitude |
remarks |
max_distance |
Notes:
- Ensure that the
