Advisory UAV operations
Endpoint: POST /v1/advisory
GeoJSON Example:
"id": "Advisory123",
"call_sign": "UAV_Alpha",
"last_update": 1738142598,
"max_altitude": 150,
"remarks": "Surveying area"
"coordinates": [
[4.39201, 50.69378],
[4.39300, 50.69400],
[4.39400, 50.69500],
[4.39201, 50.69378]
GeoJSON Example:
"id": "my_advisory_id2",
"max_distance": 500,
"remarks": "Inspection rails"
"type": "Point",
"coordinates": [
4.4,
50.7
"id": "my_advisory_id1",
"max_altitude": 111,
"coordinates": [
[4.39201, 50.69378]
"type": "Point",
"coordinates": [
4.4,
50.7
call_sign |
max_altitude |
remarks |
max_distance |
"status": "success",
Notes:
- Ensure that the
max_distanceproperty is required to define the radius of operation. Thelast_updatetimestamp must be inseconds since epoch (UTC-0).
2. Retrieve Active Advisories
Endpoint: GET /v1/advisory
x-api-key<your_api_key>Query Parameters:
viewportstringsouthwest_lat,southwest_lng,northeast_lat,northeast_lngaltitude_minintaltitude_maxintExample Request:
x-api-key: your_api_key
"remarks": "Surveying area",
"operationArea": {
"coordinates": [
[4.39201, 50.69378]
"latitude": 50.7,
"longitude": 4.4,
"operationArea": {
"type": "Point",
"coordinates": [4.4, 50.7],
"radius": 500
Response Codes:
Summary
max_distanceviewportThis structured documentation ensures that SafeSky UAV operators can publish and retrieve advisory messages efficiently, promoting better airspace awareness and safety. 🚁
