Advisory UAV operations
Endpoint: POST /v1/advisory
  • x-api-key: <your_api_key>
GeoJSON Example:
        "id": "Advisory123",
        "call_sign": "UAV_Alpha",
        "last_update": 1738142598,
        "max_altitude": 150,
        "remarks": "Surveying area"
        "coordinates": [
            [4.39201, 50.69378],
            [4.39300, 50.69400],
            [4.39400, 50.69500],
            [4.39201, 50.69378]
GeoJSON Example:
        "id": "my_advisory_id2",
        "max_distance": 500,
        "remarks": "Inspection rails"
        "type": "Point",
        "coordinates": [
          4.4,
          50.7
{ "type": "FeatureCollection", "features": [ { "type": "Feature", "properties": { "id": "my_advisory_id1", "max_altitude": 111, "last_update": {{$timestamp}}, "call_sign": "Advisory test with polygon", "remarks": "Inspection powerlines" }, "geometry": { "type": "Polygon", "coordinates": [ [ [4.39201, 50.69378], [4.39300, 50.69400], [4.39400, 50.69500], [4.39201, 50.69378] ] ] } }, { "type": "Feature", "properties": { "id": "my_advisory_id2", "max_altitude": 150, "max_distance": 500, "last_update": {{$timestamp}}, "call_sign": "Advisory test with a point", "remarks": "Inspection rails" }, "geometry": { "type": "Point", "coordinates": [ 4.4, 50.7 ] } } ] }
GeoJSON Example:
The following example demonstrates how to publish:
  • A polygon-based advisory representing an inspection area.
  • A point-based advisory with a specified radius.
        "coordinates": [
            [4.39201, 50.69378]
        "type": "Point",
        "coordinates": [
          4.4,
          50.7
id string Yes A unique identifier for the advisory message. This helps in tracking and managing advisories.
call_sign string No The call sign associated with the UAV operation. It can be used for easy identification.
last_update long Yes The timestamp of the last update in seconds since epoch (UTC-0), ensuring the advisory's relevance.
max_altitude int Yes The maximum altitude (in meters AMSL) at which UAV operations are expected to take place.
remarks string No Free text comments providing additional information about the advisory (e.g., purpose of operation).
max_distance int Yes (for Point) The radius (in meters) defining the UAV operation area when using a point advisory.
  • 201 Created: Advisory information published successfully.
  • 400 Bad Request: Invalid parameters or failed authentication.
  "status": "success",
Notes:
  • Ensure that the coordinates for a polygon form a closed loop by repeating the first coordinate at the end of the array.
  • When using a point, the max_distance property is required to define the radius of operation.
  • The last_update timestamp must be in seconds since epoch (UTC-0).
2. Retrieve Active Advisories
Endpoint: GET /v1/advisory
viewport string Yes Bounding box for retrieving advisories, formatted as southwest_lat,southwest_lng,northeast_lat,northeast_lng. N/A
altitude_min int No Filter advisories below the given altitude in AMSL meters. Zero means 'unused'. 0
altitude_max int No Filter advisories above the given altitude in AMSL meters. Zero means 'unused'. 0
x-api-key: your_api_key
    "remarks": "Surveying area",
    "operationArea": {
      "coordinates": [
          [4.39201, 50.69378]
    "latitude": 50.7,
    "longitude": 4.4,
    "operationArea": {
      "type": "Point",
      "coordinates": [4.4, 50.7],
      "radius": 500
Response Codes:
  • 200 OK: Returns a list of active advisories.
  • 400 Bad Request: Invalid parameters or authentication failure.
Summary
  • Polygon-based advisories define an operational area using multiple geographic points.
  • Point-based advisories define an operational area using a central point and a radius (max_distance).
  • The viewport parameter is used to filter advisories in a specific geographical area.
  • Altitude filters help narrow advisories to specific height ranges.
