Advisory UAV operations
Endpoint: POST /v1/advisory
GeoJSON Example:
        "id": "Advisory123",
        "call_sign": "UAV_Alpha",
        "last_update": 1738142598,
        "max_altitude": 150,
        "remarks": "Surveying area"
        "coordinates": [
            [4.39201, 50.69378],
            [4.39300, 50.69400],
            [4.39400, 50.69500],
            [4.39201, 50.69378]
GeoJSON Example:
        "id": "my_advisory_id2",
        "max_distance": 500,
        "remarks": "Inspection rails"
        "type": "Point",
        "coordinates": [
          4.4,
          50.7
{ "type": "FeatureCollection", "features": [ { "type": "Feature", "properties": { "id": "my_advisory_id1", "max_altitude": 111, "last_update": {{$timestamp}}, "call_sign": "Advisory test with polygon", "remarks": "Inspection powerlines" }, "geometry": { "type": "Polygon", "coordinates": [ [ [4.39201, 50.69378], [4.39300, 50.69400], [4.39400, 50.69500], [4.39201, 50.69378] ] ] } }, { "type": "Feature", "properties": { "id": "my_advisory_id2", "max_altitude": 150, "max_distance": 500, "last_update": {{$timestamp}}, "call_sign": "Advisory test with a point", "remarks": "Inspection rails" }, "geometry": { "type": "Point", "coordinates": [ 4.4, 50.7 ] } } ] }
GeoJSON Example
The following example demonstrates how to publish:
        "coordinates": [
            [4.39201, 50.69378]
        "type": "Point",
        "coordinates": [
          4.4,
          50.7
call_sign |
max_altitude |
remarks |
max_distance |
  "status": "success",
Notes:
- Ensure that the
max_distanceproperty is required to define the radius of operation. - The
last_updatetimestamp must be in seconds since epoch (UTC-0).
2. Retrieve Active Advisories
Endpoint: GET /v1/advisory
viewport |
N/A |
altitude_min |
altitude_max |
x-api-key: your_api_key
    "remarks": "Surveying area",
    "operationArea": {
      "coordinates": [
          [4.39201, 50.69378]
    "latitude": 50.7,
    "longitude": 4.4,
    "operationArea": {
      "type": "Point",
      "coordinates": [4.4, 50.7],
      "radius": 500
Response Codes:
- 200 OK: Returns a list of active advisories.
 - 400 Bad Request: Invalid parameters or authentication failure.
Summary
- Polygon-based advisories define an operational area using multiple geographic points.
 - Point-based advisories define an operational area using a central point and a radius (
max_distance). - The
viewportparameter is used to filter advisories in a specific geographical area. - Altitude filters help narrow advisories to specific height ranges.
