Advisory UAV operations
Endpoint: POST /v1/advisory
GeoJSON Example:
"id": "Advisory123",
"call_sign": "UAV_Alpha",
"last_update": 1738142598,
"max_altitude": 150,
"remarks": "Surveying area"
"coordinates": [
[4.39201, 50.69378],
[4.39300, 50.69400],
[4.39400, 50.69500],
[4.39201, 50.69378]
GeoJSON Example:
"id": "my_advisory_id2",
"max_distance": 500,
"remarks": "Inspection rails"
"type": "Point",
"coordinates": [
4.4,
50.7
GeoJSON Example
The following example demonstrates how to publish:
"id": "my_advisory_id1",
"max_altitude": 111,
"coordinates": [
[4.39201, 50.69378]
"type": "Point",
"coordinates": [
4.4,
50.7
call_sign |
max_altitude |
remarks |
max_distance |
"status": "success",
Notes:
- Ensure that the
max_distanceproperty is required to define the radius of operation. - The
last_updatetimestamp must be in seconds since epoch (UTC-0).
2. Retrieve Active Advisories
Endpoint: GET /v1/advisory
viewport |
N/A |
altitude_min |
altitude_max |
x-api-key: your_api_key
"remarks": "Surveying area",
"operationArea": {
"coordinates": [
[4.39201, 50.69378]
"latitude": 50.7,
"longitude": 4.4,
"operationArea": {
"type": "Point",
"coordinates": [4.4, 50.7],
"radius": 500
Response Codes:
- 200 OK: Returns a list of active advisories.
- 400 Bad Request: Invalid parameters or authentication failure.
Summary
- Polygon-based advisories define an operational area using multiple geographic points.
- Point-based advisories define an operational area using a central point and a radius (
max_distance). - The
viewportparameter is used to filter advisories in a specific geographical area. - Altitude filters help narrow advisories to specific height ranges.
