Advisory UAV operations
Here is the updated documentation with a clear distinction between publishing a polygon and publishing a point with a radius in the advisory API.
Advisory UAV Operations
Endpoint: POST /v1/advisory
GeoJSON Example:
"id": "Advisory123",
"call_sign": "UAV_Alpha",
"last_update": 1738142598,
"max_altitude": 150,
"remarks": "Surveying area"
"coordinates": [
[4.39201, 50.69378],
[4.39300, 50.69400],
[4.39400, 50.69500],
[4.39201, 50.69378]
GeoJSON Example:
"id": "my_advisory_id2",
"max_distance": 500,
"remarks": "Inspection rails"
"type": "Point",
"coordinates": [
4.4,
50.7
"id": "my_advisory_id1",
"max_altitude": 111,
"coordinates": [
[4.3948,39201, 50.6831]69378],
[4.3952,39300, 50.6832]69400],
[4.3958,39400, 50.6835]69500],
[4.3963,39201, 50.6838],
[4.4072, 50.6902],
[4.4075, 50.6903],
[4.4081, 50.6905],
[4.4085, 50.6907],
[4.4092, 50.6910],
[4.4096, 50.6912],
[4.4103, 50.6915],
[4.4106, 50.6917],
[4.4110, 50.6920],
[4.4113, 50.6922],
[4.4116, 50.6925],
[4.4118, 50.6927],
[4.4120, 50.6930],
[4.4121, 50.6932],
[4.4120, 50.6935],
[4.4118, 50.6937],
[4.4115, 50.6940],
[4.3750, 50.7150],
[4.3748, 50.7153],
[4.3746, 50.7155],
[4.3742, 50.7158],
[4.3740, 50.7160],
[4.3735, 50.7162],
[4.3733, 50.7163],
[4.3435, 50.7280],
[4.3432, 50.7281],
[4.3426, 50.7283],
[4.3423, 50.7284],
[4.3416, 50.7286],
[4.3412, 50.7287],
[4.3405, 50.7288],
[4.3402, 50.7289],
[4.3395, 50.7290],
[4.3392, 50.7290],
[4.3385, 50.7291],
[4.3382, 50.7291],
[4.3376, 50.7290],
[4.3373, 50.7289],
[4.3367, 50.7287],
[4.3365, 50.7286],
[4.3360, 50.7284],
[4.3358, 50.7282],
[4.3200, 50.7210],
[4.3195, 50.7208],
[4.3193, 50.7207],
[4.3189, 50.7205],
[4.3187, 50.7203],
[4.3185, 50.7200],
[4.3184, 50.7198],
[4.3182, 50.7195],
[4.3181, 50.7193],
[4.3948, 50.6831]69378]
"type": "Point",
"coordinates": [
4.4,
50.7
GeoJSON Example
The following example demonstrates how to publish:
"coordinates": [
[4.39201, 50.69378]
"type": "Point",
"coordinates": [
4.4,
50.7
call_sign |
max_altitude |
remarks |
max_distance |
"status": "success",
Notes:
- Ensure that the
max_distanceproperty is required to define the radius of operation. - The
last_updatetimestamp must be in seconds since epoch (UTC-0).
2. Retrieve Active Advisories
Endpoint: GET /v1/advisory
viewport |
N/A |
altitude_min |
altitude_max |
x-api-key: your_api_key
"remarks": "Surveying area",
"operationArea": {
"coordinates": [
[4.39201, 50.69378]
"latitude": 50.7,
"longitude": 4.4,
"operationArea": {
"type": "Point",
"coordinates": [4.4, 50.7],
"radius": 500
Response Codes:
- 200 OK: Returns a list of active advisories.
- 400 Bad Request: Invalid parameters or authentication failure.
Summary
- Polygon-based advisories define an operational area using multiple geographic points.
- Point-based advisories define an operational area using a central point and a radius (
max_distance). - The
viewportparameter is used to filter advisories in a specific geographical area. - Altitude filters help narrow advisories to specific height ranges.
