Advisory UAV operations
Here is the updated documentation with a clear distinction between publishing a polygon and publishing a point with a radius in the advisory API.
Advisory UAV Operations
The SafeSky API enables the management of advisory information for UAV operations, allowing for the publication of UAV activity areas and retrieval of active advisories within specified parametersparameters.
Endpoint: POST /v1/advisory
  • x-api-key: <your_api_key>
The request body should be a JSONGeoJSON stringstructure representingcontaining theone GeoJSONor many advisory areas. The advisory area can be represented using either a polygon or a point with a radius.
Publishing a Polygon Advisory
The advisory defines an area of theUAV advisoryactivity area(s)using a polygon with specific properties.
GeoJSON Example:
        "id": "Advisory123",
        "call_sign": "UAV_Alpha",
        "last_update": 1738142598,
        "max_altitude": 150,
        "remarks": "Surveying area"
        "coordinates": [
            [4.39201, 50.69378],
            [4.39300, 50.69400],
            [4.39400, 50.69500],
            [4.39201, 50.69378]
Publishing a Point Advisory with a Radius
Instead of a polygon, a point can be used to represent a UAV operation with a maximum radius.
TheGeoJSON Example:
        "id": "my_advisory_id2",
        "max_distance": 500,
        "remarks": "Inspection rails"
        "type": "Point",
        "coordinates": [
          4.4,
          50.7
{ "type": "FeatureCollection", "features": [ { "type": "Feature", "properties": { "id": "my_advisory_id1", "max_altitude": 111, "last_update": {{$timestamp}}, "call_sign": "Advisory test with polygon", "remarks": "Inspection powerlines" }, "geometry": { "type": "Polygon", "coordinates": [ [ [4.3948, 50.6831], [4.3952, 50.6832], [4.3958, 50.6835], [4.3963, 50.6838], [4.4072, 50.6902], [4.4075, 50.6903], [4.4081, 50.6905], [4.4085, 50.6907], [4.4092, 50.6910], [4.4096, 50.6912], [4.4103, 50.6915], [4.4106, 50.6917], [4.4110, 50.6920], [4.4113, 50.6922], [4.4116, 50.6925], [4.4118, 50.6927], [4.4120, 50.6930], [4.4121, 50.6932], [4.4120, 50.6935], [4.4118, 50.6937], [4.4115, 50.6940], [4.3750, 50.7150], [4.3748, 50.7153], [4.3746, 50.7155], [4.3742, 50.7158], [4.3740, 50.7160], [4.3735, 50.7162], [4.3733, 50.7163], [4.3435, 50.7280], [4.3432, 50.7281], [4.3426, 50.7283], [4.3423, 50.7284], [4.3416, 50.7286], [4.3412, 50.7287], [4.3405, 50.7288], [4.3402, 50.7289], [4.3395, 50.7290], [4.3392, 50.7290], [4.3385, 50.7291], [4.3382, 50.7291], [4.3376, 50.7290], [4.3373, 50.7289], [4.3367, 50.7287], [4.3365, 50.7286], [4.3360, 50.7284], [4.3358, 50.7282], [4.3200, 50.7210], [4.3195, 50.7208], [4.3193, 50.7207], [4.3189, 50.7205], [4.3187, 50.7203], [4.3185, 50.7200], [4.3184, 50.7198], [4.3182, 50.7195], [4.3181, 50.7193], [4.3948, 50.6831] ] ] } }, { "type": "Feature", "properties": { "id": "my_advisory_id2", "max_altitude": 150, "max_distance": 500, "last_update": {{$timestamp}}, "call_sign": "Advisory test with a point", "remarks": "Inspection rails" }, "geometry": { "type": "Point", "coordinates": [ 4.4, 50.7 ] } } ] }
Each advisory must include inside the properties element of the GeoJSON the following parameter:properties:
id string Yes A unique identifier for the advisory message. This helps in tracking and managing advisories.
call_sign string No The call sign associated with the UAV operation. It can be used for easy identification.
last_update long Yes The timestamp of the last update in seconds since epoch (UTC-0), ensuring the advisory's relevance.
max_altitude int Yes The maximum altitude (in meters AMSL) at which UAV operations are expected to take place.
remarks string No Free text comments providing additional information about the advisory (e.g., purpose of operation).
max_distance int Yes (for Point) The radius (in meters) defining the UAV operation area when using a point advisory.
POST /v1/advisory
x-api-key: your_api_key
        "coordinates": [
            [4.39201, 50.69378]
  • 201 Created: Advisory information published successfully.
  • 400 Bad Request: Invalid parameters or failed authentication.
  "status": "success",
Notes:
  • Ensure that the coordinates for a polygon form a closed loop by repeating the first coordinate at the end of the array.
  • When using a point, the max_distance property is required to define the radius of operation.
The last_update timestamp must be in seconds since epoch (UTC-0).
2. Retrieve Active Advisories
Endpoint: GET /v1/advisory
viewport string Yes Bounding box for retrieving advisories, formatted as southwest_lat,southwest_lng,northeast_lat,northeast_lng. N/A
altitude_min int No Filter advisories below the given altitude in AMSL meters. Zero means 'unused'. 0
altitude_max int No Filter advisories above the given altitude in AMSL meters. Zero means 'unused'. 0
    200 OK: Returns a list of active advisories within the specified parameters. 400 Bad Request: Invalid parameters or failed authentication.
        "remarks": "Surveying area",
        "operationArea": {
          "coordinates": [
              [4.39201, 50.69378]
        "latitude": 50.7,
        "longitude": 4.4,
        "operationArea": {
          "type": "Point",
          "coordinates": [4.4, 50.7],
          "radius": 500
    NotesResponse Codes:
      200 OK: Returns a list of active advisories. 400 Bad Request: Invalid parameters or authentication failure.
      Summary
        Polygon-based advisories define an operational area using multiple geographic points. Point-based advisories define an operational area using a central point and a radius (max_distance). The viewport parameter definesis theused to filter advisories in a specific geographical area to search for active advisories.area. Altitude filters (altitude_min and altitude_max) help narrow down advisories to specific altitudeheight ranges.
