Advisory UAV operations
Here is the updated documentation with a clear distinction between publishing a polygon and publishing a point with a radius in the advisory API.
Advisory UAV Operations
Endpoint: POST /v1/advisory
Publishing a Polygon Advisory
GeoJSON Example:
"id": "Advisory123",
"call_sign": "UAV_Alpha",
"last_update": 1738142598,
"max_altitude": 150,
"remarks": "Surveying area"
"coordinates": [
[4.39201, 50.69378],
[4.39300, 50.69400],
[4.39400, 50.69500],
[4.39201, 50.69378]
Publishing a Point Advisory with a Radius
GeoJSON Example:
"id": "my_advisory_id2",
"max_distance": 500,
"remarks": "Inspection rails"
"type": "Point",
"coordinates": [
4.4,
50.7
{ "type": "FeatureCollection", "features": [ { "type": "Feature", "properties": { "id": "my_advisory_id1", "max_altitude": 111, "last_update": {{$timestamp}}, "call_sign": "Advisory test with polygon", "remarks": "Inspection powerlines" }, "geometry": { "type": "Polygon", "coordinates": [ [ [4.3948, 50.6831], [4.3952, 50.6832], [4.3958, 50.6835], [4.3963, 50.6838], [4.4072, 50.6902], [4.4075, 50.6903], [4.4081, 50.6905], [4.4085, 50.6907], [4.4092, 50.6910], [4.4096, 50.6912], [4.4103, 50.6915], [4.4106, 50.6917], [4.4110, 50.6920], [4.4113, 50.6922], [4.4116, 50.6925], [4.4118, 50.6927], [4.4120, 50.6930], [4.4121, 50.6932], [4.4120, 50.6935], [4.4118, 50.6937], [4.4115, 50.6940], [4.3750, 50.7150], [4.3748, 50.7153], [4.3746, 50.7155], [4.3742, 50.7158], [4.3740, 50.7160], [4.3735, 50.7162], [4.3733, 50.7163], [4.3435, 50.7280], [4.3432, 50.7281], [4.3426, 50.7283], [4.3423, 50.7284], [4.3416, 50.7286], [4.3412, 50.7287], [4.3405, 50.7288], [4.3402, 50.7289], [4.3395, 50.7290], [4.3392, 50.7290], [4.3385, 50.7291], [4.3382, 50.7291], [4.3376, 50.7290], [4.3373, 50.7289], [4.3367, 50.7287], [4.3365, 50.7286], [4.3360, 50.7284], [4.3358, 50.7282], [4.3200, 50.7210], [4.3195, 50.7208], [4.3193, 50.7207], [4.3189, 50.7205], [4.3187, 50.7203], [4.3185, 50.7200], [4.3184, 50.7198], [4.3182, 50.7195], [4.3181, 50.7193], [4.3948, 50.6831] ] ] } }, { "type": "Feature", "properties": { "id": "my_advisory_id2", "max_altitude": 150, "max_distance": 500, "last_update": {{$timestamp}}, "call_sign": "Advisory test with a point", "remarks": "Inspection rails" }, "geometry": { "type": "Point", "coordinates": [ 4.4, 50.7 ] } } ] }
call_sign |
max_altitude |
remarks |
max_distance |
"status": "success",
Notes:
- Ensure that the
max_distanceproperty is required to define the radius of operation. - The
last_updatetimestamp must be in seconds since epoch (UTC-0).
2. Retrieve Active Advisories
Endpoint: GET /v1/advisory
viewport |
N/A |
altitude_min |
altitude_max |
x-api-key: your_api_key
"remarks": "Surveying area",
"operationArea": {
"coordinates": [
[4.39201, 50.69378]
"latitude": 50.7,
"longitude": 4.4,
"operationArea": {
"type": "Point",
"coordinates": [4.4, 50.7],
"radius": 500
Response Codes:
- 200 OK: Returns a list of active advisories.
- 400 Bad Request: Invalid parameters or authentication failure.
Summary
- Polygon-based advisories define an operational area using multiple geographic points.
- Point-based advisories define an operational area using a central point and a radius (
max_distance). - The
viewportparameter is used to filter advisories in a specific geographical area. - Altitude filters help narrow advisories to specific height ranges.
