Advisory UAV operations
The SafeSky API enables the management of advisory information for UAV operations, allowing for the publication of UAV activity areas and retrieval of active advisories within specified parameters
Endpoint: POST /v1/advisory
The request body should be a JSON string representing the GeoJSON of the advisory area(s).
The GeoJSON must include inside the properties element of the GeoJSON the following parameter:
call_sign |
max_altitude |
remarks |
POST /v1/advisory
x-api-key: your_api_key
"id": "Advisory123",
"call_sign": "UAV_Alpha",
"last_update": 1738142598,
"max_altitude": 150,
"remarks": "Surveying area"
"coordinates": [
[4.39201, 50.69378],
[4.39300, 50.69400],
[4.39400, 50.69500],
[4.39201, 50.69378]
Notes:
- Ensure that the
coordinatesfor a polygon form a closed loop by repeating the first coordinate at the end of the array.
2. Retrieve Active Advisories
Endpoint: GET /v1/advisory
viewport |
N/A |
altitude_min |
altitude_max |
- 200 OK: Returns a list of active advisories within the specified parameters.
"remarks": "Surveying area",
"operationArea": {
"coordinates": [
[4.39201, 50.69378]
Notes:
- The
viewportparameter defines the geographical area to search for active advisories. - Altitude filters (
altitude_minandaltitude_max) help narrow down advisories to specific altitude ranges.
