Advisory UAV operations
The SafeSky API enables the management of advisory information for UAV operations, allowing for the publication of UAV activity areas and retrieval of active advisories within specified parameters
Endpoint: POST /v1/advisory
    Content-Type: application/json x-api-key: <your_api_key>
    The request body should be a JSON string representing the GeoJSON of the advisory area(s).
    The GeoJSON must include inside the properties element of the GeoJSON the following parameter:
    Parameter Type Required Description id string Yes A unique identifier for the advisory message. This helps in tracking and managing advisories. call_sign string No The call sign associated with the UAV operation. It can be used for easy identification. last_update long Yes The timestamp of the last update in seconds since epoch (UTC-0), ensuring the advisory's relevance. max_altitude int Yes The maximum altitude (in meters AMSL) at which UAV operations are expected to take place. remarks string No Free text comments providing additional information about the advisory (e.g., purpose of operation).
    POST /advisory
    x-api-key: your_api_key
            "id": "Advisory123",
            "call_sign": "UAV_Alpha",
            "last_update": 1738142598,
            "max_altitude": 150,
            "remarks": "Surveying area"
            "coordinates": [
                [4.39201, 50.69378],
                [4.39300, 50.69400],
                [4.39400, 50.69500],
                [4.39201, 50.69378]
      201 Created: Advisory information published successfully. 400 Bad Request: Invalid parameters or failed authentication.
      Notes:
        Ensure that the coordinates for a polygon form a closed loop by repeating the first coordinate at the end of the array.
        2. Retrieve Active Advisories
        Endpoint: GET /v1/advisory
        Parameter Type Required Description Default viewport string Yes Bounding box for retrieving advisories, formatted as southwest_lat,southwest_lng,northeast_lat,northeast_lng. N/A altitude_min int No Filter advisories below the given altitude in AMSL meters. Zero means 'unused'. 0 altitude_max int No Filter advisories above the given altitude in AMSL meters. Zero means 'unused'. 0
          200 OK: Returns a list of active advisories within the specified parameters. 400 Bad Request: Invalid parameters or failed authentication.
              "lastUpdate": 1738142598,
              "remarks": "Surveying area",
              "operationArea": {
                "coordinates": [
                    [4.39201, 50.69378]
          Notes:
            The viewport parameter defines the geographical area to search for active advisories. Altitude filters (altitude_min and altitude_max) help narrow down advisories to specific altitude ranges.
