8 - FAQ
  • Mount it vertical inside your aircraft.
The Aero Tracker is designed to show only nearby traffic when connected to your Electronic Flight Bag (EFB).
By default, it filters and displays aircraft within ±3000 feet vertically and within a 20 NM radius, prioritised by distance from your current position. This ensures your navigation app remains focused and free from clutter, showing only the most relevant traffic for your flight.
In contrast, the SafeSky app may show a broader traffic view to improve overall situational awareness. If your smartphone or tablet running SafeSky also has an LTE connection, it can further enhance visibility by combining traffic received via the Aero Tracker and your phone or tablet device.
This dual approach strikes a balance between clear, essential traffic on your EFB and comprehensive awareness in the SafeSky app.
  • When activated, traffic coming from the SafeSky network will appear with a 'sy' prefix in the callsign.
  • Air-to-air traffic will continue to display its normal callsign without any prefix.
To enable this option:
  1. Turn ON your Aero Tracker.
  2. Open the SafeSky App and go to the "External Traffic" menu.
  3. Select your Aero Tracker device from the list.
  4. Tap "Configure" and enable the "Highlight SafeSky traffic" setting.
  • This SIM ensures optimal coverage by connecting to multiple telecom operators across countries, similar to international roaming.
  • Using a personal SIM is not supported, as it would compromise connectivity and the seamless integration with the SafeSky network.
🔗 See subscription details here
How do I reset the Aero Tracker to factory settings?
You can perform a factory reset directly from the Aero Tracker device.
This operation will:
  • ❌ Erase all stored configuration and pairing information
  • 🔄 Unpair the device from your SafeSky account
  • 🧾 Reset all parameters to factory defaults
  • ✅ Allow the device to be freshly paired with a new or existing SafeSky account
⚠️ Use this only if you are experiencing issues or need to transfer ownership.
To reset to factory settings:
  1. Turn off your Aero Tracker completely.
  2. Press and hold the power button.
  3. Observe the yellow LEDs lighting up from bottom to top.
  4. Release the button after the last LED is yellow. The LED will turn red
  5. The device will restart and all data will be erased.
How can I enable the FLARM licence on my Aero Tracker?
FLARM reception is licensed by FLARM Technology and requires a separate one-time license.
  • This license must be purchased separately from your Aero Tracker.
  • You can buy it from Avionix Webshop.
Once the license is activated, you'll be able to update your firmware to enable FLARM support.
What happens after activation?
  • Your Aero Tracker’s built-in radio receiver will begin decoding FLARM signals.
  • FLARM traffic will appear in your favorite EFB (SkyDemon, EasyVFR, etc.) and in the SafeSky App, displayed just like any other nearby aircraft.
How to confirm that FLARM is active?
To verify that your Aero Tracker has FLARM enabled:
  1. Open the SafeSky App.
  2. Go to the "External Traffic" menu and select your Aero Tracker.
  3. Check the device status screen: you should see a "FLARM" label displayed if the license is active.
What do the Aero Tracker LED indicators mean?
The Aero Tracker uses a vertical strip of LED lights to communicate its current status.
Each LED represents a different function or state. When powering on, the LEDs will animate to indicate the device is booting.
Green and blue flashes are normal operation and yellow and red are warning and error states
How can I register my Aero Tracker with the OGN Device Database?
You can register your Aero Tracker in the OGN Device Database to make it visible on other public tracking networks.
Registering your device allows you to:
  • Display your aircraft on platforms such as live.glidernet.org and other OGN-based tracking sites.
  • Facilitate Search and Rescue (SAR) operations, making your aircraft easier to locate if needed.
  • Contribute to overall traffic awareness for other pilots and ATC.
  1. Go to http://wiki.glidernet.org/ddb.
  2. Retrieve your Aero Tracker Device ID:
    • Connect to your Aero Tracker.
    • Tap the information icon (ℹ️) in the top-left corner.
    • Your ADSL Address willcorresponds beto displayedyour there.Device ID on OGN.
  3. Your ADSL Address Type corresponds to your Device Address Type on OGN.
  4. Enter thisyour ADSL Address as yourthe Device ID onin the OGN websiteregistration toform.
completeIf the registration.Address Type is 2, select OGN. Otherwise, select ICAO.
