8 - FAQ
  • Mount it vertical inside your aircraft.
By default, traffic is filtered to show aircraft within ±2500 feet vertically and within a 20 NM radius around your position.
  • This ensures your EFB remains uncluttered and focused on relevant traffic.
  • The SafeSky app, however, may show a broader view for situational awareness.
  • When activated, traffic coming from the SafeSky network will appear with a 'sy' prefix in the callsign.
  • Air-to-air traffic will continue to display its normal callsign without any prefix.
To enable this option:
  1. Turn ON your Aero Tracker.
  2. Open the SafeSky App and go to the "External Traffic" menu.
  3. Select your Aero Tracker device from the list.
  4. Tap "Configure" and enable the "Highlight SafeSky traffic" setting.
  • This SIM ensures optimal coverage by connecting to multiple telecom operators across countries, similar to international roaming.
  • Using a personal SIM is not supported, as it would compromise connectivity and the seamless integration with the SafeSky network.
🔗 See subscription details here
How do I reset the Aero Tracker to factory settings?
You can perform a factory reset directly from the Aero Tracker device.
This operation will:
  • ❌ Erase all stored configuration and pairing information
  • 🔄 Unpair the device from your SafeSky account
  • 🧾 Reset all parameters to factory defaults
  • ✅ Allow the device to be freshly paired with a new or existing SafeSky account
⚠️ Use this only if you are experiencing issues or need to transfer ownership.
To reset to factory settings:
  1. Turn off your Aero Tracker completely.
  2. Press and hold the power button.
  3. Observe the yellow LEDs lighting up from bottom to top.
  4. Release the button after the last LED is yellow. The LED will turn red
  5. The device will restart and all data will be erased.
