8 - FAQ
  • Mount it vertical inside your aircraft.
By default, traffic is filtered to show aircraft within ±2500 feet vertically and within a 20 NM radius around your position.
  • This ensures your EFB remains uncluttered and focused on relevant traffic.
  • The SafeSky app, however, may show a broader view for situational awareness.
  • When activated, traffic coming from the SafeSky network will appear with a 'sy' prefix in the callsign.
  • Air-to-air traffic will continue to display its normal callsign without any prefix.
To enable this option:
  1. Turn ON your Aero Tracker.
  2. Open the SafeSky App and go to the "External Traffic" menu.
  3. Select your Aero Tracker device from the list.
  4. Tap "Configure" and enable the "Highlight SafeSky traffic" setting.
  • This SIM ensures optimal coverage by connecting to multiple telecom operators across countries, similar to international roaming.
  • Using a personal SIM is not supported, as it would compromise connectivity and the seamless integration with the SafeSky network.
🔗 See pricing and details here
