8 - FAQ
- Mount it vertical inside your aircraft.
By default, traffic is filtered to show aircraft within ±20002500 feet vertically and within a 20 NM radius around your position.
- This ensures your EFB remains uncluttered and focused on relevant traffic.
- The SafeSky app, however, may show a broader view for situational awareness.
- When activated, traffic coming from the SafeSky network will appear with a 'sy' prefix in the callsign.
- Air-to-air traffic will continue to display its normal callsign without any prefix.
To enable this option:
- Turn ON your Aero Tracker.
- Open the SafeSky App and go to the "External Traffic" menu.
- Select your Aero Tracker device from the list.
- Tap "Configure" and enable the "Highlight SafeSky traffic" setting.
