8 - FAQ
For optimal performance, install the Aero Tracker in a horizontalvertical position with a clear view of the sky.
- Mount it
flat (horizontally)vertical inside your aircraft. - Make sure there are no obstacles above it, such as metal surfaces or dense materials, which could interfere with the GPS and transmission signals.
By default, traffic is filtered to show aircraft within ±2000 feet vertically and within a 20 NM radius around your position.
- This ensures your EFB remains uncluttered and focused on relevant traffic.
- The SafeSky app, however, may show a broader view for situational awareness.
