8 - FAQ
- Mount it vertical inside your aircraft.
By default, traffic is filtered to show aircraft within ±2000 feet vertically and within a 20 NM radius around your position.
- This ensures your EFB remains uncluttered and focused on relevant traffic.
- The SafeSky app, however, may show a broader view for situational awareness.
