8 - FAQ
For optimal performance, install the Aero Tracker in a horizontal position with a clear view of the sky.
  • Mount it flat (horizontally) inside your aircraft.
By default, traffic is filtered to show aircraft within ±2000 feet vertically and within a 20 NM radius around your position.
  • This ensures your EFB remains uncluttered and focused on relevant traffic.
  • The SafeSky app, however, may show a broader view for situational awareness.
