8 - FAQ
For optimal performance, install the Aero Tracker in a horizontal position with a clear view of the sky.
  • Mount it flat (horizontally) inside your aircraft.
    Continuous tracking and data transmission may shorten battery life. Using power-saving features or connecting to an external power source can help extend operating time during longer flights.
