1 - Introduction
- General aviation planes
- Gliders
- Paramotors
- Paragliders
- Trikes
- Ultra-lights
- Helicopters
- Drones
Buy Aero Tracker
1 - Dual Traffic Awareness
Air-to-Air
- ADS-B (reception only)
- ADS-L
- OGN-Tracker
- FANET
- The SafeSky network
- FLARM
- Mode-S using MLAT
- PilotAware
- MicroTrack
- Remote ID
- Navigation Apps (such as Air NAvigation Pro, EasyVFR...)
- Paragliding and paramotors software and hardware (such as XCTrack, Gaggle, Cloud-Dash...)
- Electronic devices (such as FlyMaster, Syride,SkyTraxx...)
- Drones
2 - DataSheet
Aero Tracker Datasheet (PDF)
3 - What Traffic Should I See?
Understanding the traffic displayed by your Aero Tracker depends on how you're using it—either through the SafeSky App or an Electronic Flight Bag (EFB) such as SkyDemon, Air Navigation Pro, or EasyVFR. Each setup provides a tailored experience to balance clarity and situational awareness.
This filtering is applied regardless of the traffic source—whether it's from air-to-air protocols (ADS-B, ADS-L, FANET, OGN-Tracker) or via the SafeSky LTE network.
📱 Using the SafeSky App
sy⚠️ Note: This feature may cause distraction during flight. We recommend enabling it only during pre-flight or post-flight analysis.
✅ Summary
4 - Standards and Compatibility with EASA ADS-L Coalition
Fly Safe,
The SafeSky Team ✈️
