1 - Introduction
- General aviation planes
- Gliders
- Paramotors
- Paragliders
- Trikes
- Ultra-lights
- Helicopters
- Drones
Buy Aero Tracker
1 - Dual Traffic Awareness
Air-to-Air
- ADS-B (reception only)
- ADS-L
OGNOGN-Tracker- FANET
- The SafeSky network
- FLARM
- Mode-S using MLAT
- PilotAware
- MicroTrack
2 - DataSheet
Aero Tracker Datasheet (PDF)
3 - What Traffic Should I See?
Understanding the traffic displayed by your Aero Tracker depends on how you're using it—either through the SafeSky App or an Electronic Flight Bag (EFB) such as SkyDemon, Air Navigation Pro, or EasyVFR. Each setup provides a tailored experience to balance clarity and situational awareness.
3🧭 Using the Aero Tracker with an EFB
This filtering is applied regardless of the traffic source—whether it's from air-to-air protocols (ADS-B, ADS-L, FANET, OGN-Tracker) or via the SafeSky LTE network.
📱 Using the SafeSky App
sy prefix in the callsign
Air-to-air traffic keeps its standard callsign with no prefix
✅ Summary
4 - Standards and Compatibility with EASA ADS-L Coalition
Fly Safe,
The SafeSky Team ✈️
