4 - FAQ
1 - Software updateUpdate isNot not working?Working?
It'If the Aero Tracker isn’t updating, it’s possible thatthe device has an older firmware version. In this case, you’ll need to perform a manual update:
  1. Turn off the Aero Tracker you have received contains an older firmware. You need to update it manually once for all:
    • Turn off the Aero TrackerTracker.
    • downloadDownload the firmware manually from herethis link.
    • extractRemove the SD card from the Aero Tracker and connect it to ayour computercomputer.
    • copyCopy the downloaded file to the root directory of the SD card.
    • Rename the file to the root of the SD cardfirmware.bin.
    • rename the file to firmware.bin
    • PutReinsert the SD card back ininto the Aero Tracker,Tracker and power it on.
The updatedevice should beautomatically complete.detect and apply the firmware update.
2 - LTE isNot not working?Working?
If youyou’re areexperiencing providingissues yourwith ownLTE connectivity, follow these steps:
  • Using Your Own SIM card,Card?
    make
      sure from
    • Open the SafeSky appApp and go to "My Devices".
    • Click "Configure" and ensure the APN forsettings match your telecom provider.
      provider’s details.
  • If you are usingUsing the build-inBuilt-In IOTSafeSky cardIoT fromSIM?
    SafeSky,
      make
    • Verify surethat the APN is set to em in the SafeSky App under "em"Configure".
This should resolve most LTE connection issues.
