4 - FAQ
1 - Software Update Not Working?
If the Aero Tracker isn’t updating, it’s possible the device has an older firmware version. In this case, you’ll need to perform a manual update:
- Turn off the Aero Tracker.
- Download the firmware manually from this link.
- Remove the SD card from the Aero Tracker and connect it to your computer.
- Copy the downloaded file to the root directory of the SD card.
- Rename the file to
firmware.bin
. - Reinsert the SD card into the Aero Tracker and power it on.
The device should automatically detect and apply the firmware update.
2 - LTE Not Working?
If you’re experiencing issues with LTE connectivity, follow these steps:
Using Your Own SIM Card?
- Open the SafeSky App and go to "My Devices".
- Click "Configure" and ensure the APN settings match your telecom provider’s details.
Using the Built-In SafeSky IoT SIM?
- Verify that the APN is set to
em
in the SafeSky App under "Configure".
This should resolve most LTE connection issues.
