3 - Software update
When
How to Update the SafeSkyAero-Tracker appFirmware
To update the aero-tracker firmware, follow these steps:
  1. Ensure the aero-tracker is connectedin Wi-Fi mode (instead of Bluetooth mode).
    • Quickly double-tap the power button to switch between modes.
  2. Connect your phone to the Aero Aero-Tracker Wifi,Wi-Fi network.
    • The system will check for any available software updates.
  3. If an update is available, you will see ifan a"Update newavailable" software update is available.button.
    • Simply click the "Update available" buttonit and follow the processon-screen instructions to performcomplete Aero Trackerthe update.
What to Do If You're Running an Older Firmware?
If your aero-tracker firmware is too outdated to update over Wi-Fi, follow these manual steps:
  1. Remove the SD card from the tracker.
  2. Download the base firmware from the following link:
    Capture d’écran . 2024-06-13 à 11.26.27.jpegDownload Firmware
  3. Copy the downloaded firmware.bin file to the root directory of the SD card.
  4. Reinsert the SD card into the tracker and power it on.
    • The tracker should automatically detect and apply the firmware update.
  5. Once the base firmware is installed, follow the instructions above to update to the latest version using the standard Wi-Fi method.
