2 - Device enrollement
Requirements:
You must have a beta version of SafeSky. Version can be found at the bottom of the preference page and should be 3.1.0.
Bluetooth and Wifi
The current version can only operate using either bluetooth or Wifi. The final version will support both.
When in configuration mode, you need to turn on bluethooth. When using GDL90 to your favorite navigation software, you need to turn on Wifi, expect for SkyDemon which support NMEA over bluetooth (see example below)
To switch between BlueTooth and Wifi, you need to click rapidely twice on the power button.
Paring device
Make sure there is at least one aircraft configured in SafeSky App.
Status information
  • When returning to "My devices", you should see some diagnostic information, including LTE connectivity, your location and altitude from the internet GPS. Note that for the GPS to work you need to be outside.
