Device enrollement
Make sure there is at least one aircraft configured in SafeSky App.
The process is very simple:
    1
  1. - Power on the aero tracker
  2. 2 - Open SafeSky app, and go to the "My devices" menu
    3 - Click on "Add a new device"
  4. Selectand select "AERO TRACKER"
    4 - From your phone or tablet, open the Wifi setting and connect to the aero tracker hotspot. The Wifi name should start with "aero"
  6. 5 - Return to the SafeSky app, and click "Refresh": the aero tracker should be found and "Pair device" button should appear. Select it
  7. The
    6 - Click on "Pair device" and the paring should happen.
    7 - If you click "Finish" you will see the aero tracker page.
8 - If you reconnect to the Aero Tracker Wifi, you should see some diagnostic information, including LTE connectivity, your location and altitude from the internet GPS.
