7 - Model Definition
1. Beacon Model
Fields
Yes | The unique identifier of the beacon (e.g., ICAO 24-bit hex address or SafeSky-assigned ID). |
Yes | Direction of travel in degrees, clockwise relative to true north (0–359). |
ground_speed |
Yes | Current ground speed in meters per second. |
No | Time of the event in seconds since epoch (UTC). Minimum value: 1. |
No | Current operational status of the beacon. See Status Values. |
beacon_type |
No | Aircraft category. See Beacon Types. |
transponder_type |
No | Technology used to broadcast the position. See Transponder Types. |
call_sign |
No | Beacon call sign. Only present if the pilot has a public profile. |
vertical_rate |
No | Vertical rate in m/s. Positive values indicate climbing; negative values indicate descending. |
accuracy |
No | Accuracy level of the latitude and longitude coordinates, in meters. |
altitude_accuracy |
No | Accuracy level of the altitude coordinate, in meters. |
turn_rate |
float |
remarks |
No | Free-text comments (maximum 255 characters). |
operation_area |
No | For advisory beacons, a GeoJSON string representing the declared area of activity. |
Status Values
| Value | Description |
AIRBORNE |
The beacon is in flight. |
GROUNDED |
The beacon is on the ground (taxiing, parked, or pre-flight). |
INACTIVE |
The beacon has not transmitted recently and is considered inactive. |
SAR |
Search and rescue operation. |
Example Beacon Object
"id": "3423C3",
"status": "AIRBORNE"
2. Status Model
Fields
| Field | Type | Description |
timestamp |
Unix timestamp (seconds since epoch, UTC) for this status snapshot. |
active |
Total number of currently active beacons. |
inactive |
Total number of inactive beacons. |
grounded |
Total number of grounded beacons. |
beacon_counts |
Total number of beacons tracked by the network. |
outdated_beacon_counts |
Total number of beacons with stale position data. |
transponder_types |
array |
Array of objects, each mapping a transponder type name to its count (e.g., {"ADS-B": 6200}). |
beacon_types |
array |
Array of objects, each mapping an aircraft category to its count (e.g., {"JET": 3200}). |
Example Status Object
"timestamp": 1733412793,
"active": 12540,
"inactive": 430,
"grounded": 87,
"beacon_counts": 13057,
"transponder_types": [
{ "ADS-B": 6200 },
{ "ADS-BI": 4100 },
{ "FLARM": 1800 },
{ "OGN": 740 },
{ "MODE-S": 217 }
"beacon_types": [
{ "JET": 3200 },
{ "MOTORPLANE": 2100 },
{ "HELICOPTER": 980 },
{ "GLIDER": 870 },
{ "UAV": 430 },
{ "PARA_GLIDER": 215 },
{ "BALLOON": 47 }
Altitude Reference
Coordinate System
latitude: decimal degrees, positive = North, negative = Southlongitude: decimal degrees, positive = East, negative = West- 4 decimal places of precision are sufficient for all API calls (~11 meters resolution)
