7 - Model Definition
1. Beacon Model
Fields
Field Type
Required Description id string Yes string — The unique identifier of the beacon (e.g., ICAO 24-bit hex address or SafeSky-assigned ID). latitude double Yes double — Latitude in decimal degrees. longitude double Yes double — Longitude in decimal degrees. altitude int Yes int — Height of the beacon in meters, based on GPS altitude AMSL. course int Yes int — Direction of travel in degrees, clockwise relative to true north (0–359). ground_speed int Yes int — Current ground speed in meters per second. last_update long No long — Time of the event in seconds since epoch (UTC). Minimum value: 1. status string No string — Current operational status of the beacon. See Status Values. beacon_type string No string — Aircraft category. See Beacon Types. transponder_type string No string — Technology used to broadcast the position. See Transponder Types. call_sign string No string — Beacon call sign. Only present if the pilot has a public profile. vertical_rate int No int — Vertical rate in m/s. Positive values indicate climbing; negative values indicate descending. accuracy int No int — Accuracy level of the latitude and longitude coordinates, in meters. altitude_accuracy int No int — Accuracy level of the altitude coordinate, in meters. turn_rate float No float — Turn rate in degrees per second. remarks string No string — Free-text comments (maximum 255 characters). operation_area string No string — For beaconsadvisory with activity status,beacons, a GeoJSON string representing the declared area of activity.
Status Values
Value Description
Example Beacon Object
  "id": "3423C3",
  "status": "AIRBORNE"
2. Status Model
Fields
Field Required Description
timestamp — long — Unix timestamp (seconds since epoch, UTC) for this status snapshot.
active — long — Total number of currently active beacons.
inactive — long — Total number of inactive beacons.
grounded — long — Total number of grounded beacons.
beacon_counts — int — Total number of beacons tracked by the network.
outdated_beacon_counts — int — Total number of beacons with stale position data.
transponder_types — array — Array of objects, each mapping a transponder type name to its count (e.g., {"ADS-B": 6200}).
beacon_types — array — Array of objects, each mapping an aircraft category to its count (e.g., {"JET": 3200}).
Example Status Object
  "timestamp": 1733412793,
  "active": 12540,
  "inactive": 430,
  "grounded": 87,
  "beacon_counts": 13057,
  "transponder_types": [
    { "ADS-B": 6200 },
    { "ADS-BI": 4100 },
    { "FLARM": 1800 },
    { "OGN": 740 },
    { "MODE-S": 217 }
  "beacon_types": [
    { "JET": 3200 },
    { "MOTORPLANE": 2100 },
    { "HELICOPTER": 980 },
    { "GLIDER": 870 },
    { "UAV": 430 },
    { "PARA_GLIDER": 215 },
    { "BALLOON": 47 }
Altitude Reference
Coordinate System
