# Model Definition
1. Beacon Model
Fields
operation_area string No For beacons with activity status, a GeoJSON string representing the declared area of activity.
Status Values
Value Description
Example Beacon Object (Verbose Format)
  "id": "3423C3",
  "status": "AIRBORNE"
Example Beacon Object (Optimised Format)
When the GET /v1/beacons endpoint is called with optimised=true, each beacon is returned as a compact JSON array. The element order corresponds to the field sequence of the verbose model, reducing payload size for high-density viewports.
["3423C3", 1733412793, 0, "AIRBORNE", 48.86584, 2.63723, "IBE06CK", "ADS-B", 10554, 2, 0, 205, 237, 0.0, null, null, "JET"]
Use the verbose format during development for readability. Use optimised=true in production to reduce bandwidth consumption.
2. Status Model
Fields
Field Type Description
timestamp long Unix timestamp (seconds since epoch, UTC) for this status snapshot.
active long Total number of currently active beacons.
inactive long Total number of inactive beacons.
grounded long Total number of grounded beacons.
beacon_counts int Total number of beacons tracked by the network.
outdated_beacon_counts int Total number of beacons with stale position data.
transponder_types array Array of objects, each mapping a transponder type name to its count (e.g., {"ADS-B": 6200}).
beacon_types array Array of objects, each mapping an aircraft category to its count (e.g., {"JET": 3200}).
Example Status Object
  "timestamp": 1733412793,
  "active": 12540,
  "inactive": 430,
  "grounded": 87,
  "beacon_counts": 13057,
  "transponder_types": [
    { "ADS-B": 6200 },
    { "ADS-BI": 4100 },
    { "FLARM": 1800 },
    { "OGN": 740 },
    { "MODE-S": 217 }
  "beacon_types": [
    { "JET": 3200 },
    { "MOTORPLANE": 2100 },
    { "HELICOPTER": 980 },
    { "GLIDER": 870 },
    { "UAV": 430 },
    { "PARA_GLIDER": 215 },
    { "BALLOON": 47 }
Altitude Reference
Coordinate System
