# Beacon API
The Beacon API provides access to live aircraft position data based on the open ADS-BI protocol. It allows you to retrieve real-time traffic for a geographic area, publish your own beacon, and look up individual aircraft by identifier or call sign.
Understanding Traffic in Beacon Responses
Traffic responses from the Beacon API can contain two distinct categories of objects. It is important to handle them differently in your application.
Live Beacons
Live beacons represent aircraft that are actively broadcasting their position in real time. They are the primary traffic type and include:
  • Commercial jets, general aviation, helicopters, gliders, UAVs, and other aircraft
  • Positions derived from ADS-B, FLARM, ADS-L, Mode S, OGN, or the SafeSky mobile app
  • Precise latitude/longitude with motion data (course, ground speed, vertical rate)
Live beacons are identified by a transponder_type value other than ADVISORY (e.g., ADS-B, FLARM, ADS-BI, OGN, MODE-S).
Advisory Beacons
Advisory beacons represent declared UAV operation areas rather than tracked positions. They are published by drone operators to announce active operations in a geographic zone when no live telemetry is available.
An advisory beacon is identified by:
  • transponder_type: "ADVISORY"
  • beacon_type: "UAV"
  • A populated operation_area field — a GeoJSON string describing the operational polygon or circle
Advisory beacons carry an operation_area field encoded as a JSON string. Parse it as GeoJSON to access the polygon or circle geometry. Key advisory properties:
Field Description
id Unique identifier for the operation
call_sign Operator or operation name
altitude Maximum declared altitude of the operation (AMSL, meters)
last_update Timestamp of the last advisory update (seconds since epoch)
remarks Free-text operator notes (contact details, purpose, etc.)
operation_area GeoJSON string — Polygon or Point geometry defining the operation zone
Important: Advisory objects represent declared zones of activity, not precise tracked positions. Do not treat the latitude/longitude of an advisory beacon as a real-time aircraft location — it is simply a reference point for the declared area. Never render advisory traffic with a moving aircraft icon.
Handling Mixed Responses
A single API response may contain both live and advisory beacons. Always inspect the transponder_type field to determine which rendering logic to apply:
function processBeacons(beacons) {
  for (const beacon of beacons) {
    if (beacon.transponder_type === 'ADVISORY') {
      renderAdvisoryZone(beacon);   // Render as a polygon/circle area overlay
    } else {
      renderLiveTraffic(beacon);    // Render as a moving aircraft icon
function renderAdvisoryZone(advisory) {
  // Parse the operation_area GeoJSON string
  const geoJson = JSON.parse(advisory.operation_area);
  // Render as a semi-transparent polygon or circle on the map
  // Display call_sign, altitude, and remarks as a label
Endpoints Overview
Method Endpoint Description
GET /v1/beacons Retrieve live beacons for a viewport
POST /v1/beacons Publish a single beacon
POST /v1/beacons/batch Publish multiple beacons
GET /v1/beacons/{id} Retrieve a single beacon by its ID
GET /v1/beacons/search Search beacons by call sign or aircraft ID
1. Get Beacons for a Viewport
Endpoint: GET /v1/beacons
Description:
Returns a collection of live beacons for the given viewport rectangle. This is the primary endpoint for displaying traffic on a map.
The viewport parameter defines a geographic bounding box from the south-west corner to the north-east corner: lat_min,lng_min,lat_max,lng_max.
Request Headers
Header Required Description
x-api-key Yes Your SafeSky API key
Query Parameters
viewport string Yes — Bounding box: lat_min,lng_min,lat_max,lng_max. 4 decimal places is sufficient.
show_grounded boolean No true Include beacons with GROUNDED status.
beacon_types string No — Comma-separated list of beacon types to filter on (e.g., HELICOPTER,UAV).
altitude_min int No 0 Filter out all beacons below this altitude (AMSL meters). 0 means unused.
altitude_max int No 0 Filter out all beacons above this altitude (AMSL meters). 0 means unused.
identifiers string No — Comma-separated list of beacon identifiers to filter on.
optimised boolean No false Return the optimised JSON array format instead of the verbose object format.
Example Request
Example Request with Filters
# Retrieve only helicopters and UAVs between 0 and 500 meters
curl 'https://public-api.safesky.app/v1/beacons?viewport=50.5,4.2,50.9,4.8&beacon_types=HELICOPTER,UAV&altitude_max=500' \
Response
200 OK — Returns an array of Beacon objects (see Model Definition).
The array may contain a mix of live beacons and advisory beacons. Use the transponder_type field to distinguish them (see Understanding Traffic in Beacon Responses).
Example Response — Live Beacons Only
    "id": "3423C3",
    "status": "AIRBORNE"
    "id": "F1A9E2",
    "latitude": 44.83278,
    "longitude": 6.21543,
    "beacon_type": "GLIDER",
    "transponder_type": "FLARM",
    "last_update": 1733412790,
    "altitude": 2100,
    "course": 185,
    "ground_speed": 32,
    "accuracy": 3,
Example Response — Mixed (Live + Advisory)
The following example shows a realistic mixed response containing a commercial jet (live, ADS-B), a helicopter (live, ADS-BI), and a UAV advisory zone published by a drone operator:
    "id": "3423C3",
    "id": "096E2863",
    "latitude": 50.17081,
    "longitude": 4.52680,
    "beacon_type": "HELICOPTER",
    "call_sign": "ROTORWING 30",
    "transponder_type": "ADS-BI",
    "altitude": 450,
    "altitude_accuracy": 10,
    "course": 315,
    "ground_speed": 54,
    "vertical_rate": 45,
    "id": "hx-137105",
    "call_sign": "InspectionDrone-Alpha",
    "last_update": 1733412780,
    "altitude": 120,
    "remarks": "Powerline inspection – contact: operator@example.com",
    "operation_area": "{\"type\":\"Polygon\",\"coordinates\":[[[4.39201,50.69378],[4.39300,50.69400],[4.39400,50.69500],[4.39201,50.69378]]]}",
Key observations from the mixed response:
  • The jet (3423C3) and helicopter (096E2863) are live tracked aircraft — render them as moving icons rotated to their course.
  • The UAV (hx-137105) has transponder_type: "ADVISORY" — it is not a tracked position. Parse the operation_area GeoJSON string and render it as a semi-transparent polygon overlay on the map. The altitude field holds the maximum declared altitude for the operation zone.
  • remarks may contain free-text operator contact details or operational notes — display these on user interaction (tap/hover).
Optimised Format
When optimised=true, each beacon is returned as a compact JSON array instead of a named-field object. This reduces payload size significantly for high-traffic viewports:
curl 'https://public-api.safesky.app/v1/beacons?viewport=43.1035,-2.0821,47.9943,15.3216&optimised=true' \
The element order in the optimised array follows the field sequence defined in the Beacon model. Use the verbose format during development for clarity, and switch to optimised=true in production for bandwidth efficiency.
2. Publish a Single Beacon
Endpoint: POST /v1/beacons
Description:
Publishes a new beacon position to the SafeSky network. Optionally returns nearby traffic by providing a viewport or filter parameters.
Request Headers
Content-Type Yes application/json
Query Parameters
viewport string No — If provided, returns beacons visible in this bounding box alongside the publish confirmation.
show_grounded boolean No false Include grounded beacons in the response.
aircraft_types string No — Comma-separated list of beacon types to filter the response.
altitude_delta int No — Altitude delta filter applied to the response.
Request Body
A single Beacon object. See Model Definition for the full field reference.
Required fields: id, latitude, longitude, altitude, course, ground_speed.
Example Request
curl --request POST 'https://public-api.safesky.app/v1/beacons' \
  --data '{
    "id": "MY_BEACON_01",
    "latitude": 50.6938,
    "longitude": 4.3922,
    "altitude": 350,
    "course": 90,
    "ground_speed": 45,
    "beacon_type": "MOTORPLANE",
Response
200 OK — Returns an array of nearby beacons if a viewport was provided, otherwise an empty array.
3. Publish Multiple Beacons (Batch)
Endpoint: POST /v1/beacons/batch
Description:
Publishes multiple beacon positions in a single request. Use this endpoint when managing multiple aircraft or when aggregating positions from several sources to minimise HTTP overhead.
Request Headers
Request Body
An array of Beacon objects. See Model Definition for the full field reference.
Example Request
curl --request POST 'https://public-api.safesky.app/v1/beacons/batch' \
  --data '[
      "id": "BEACON_01",
      "altitude": 350,
      "course": 90,
      "ground_speed": 45,
      "id": "BEACON_02",
      "latitude": 50.7010,
      "longitude": 4.4100,
      "altitude": 280,
      "course": 120,
      "ground_speed": 38,
Response
200 OK — Confirmation that the beacons were accepted.
4. Get a Beacon by ID
Endpoint: GET /v1/beacons/{id}
Description:
Returns the current live data for a specific beacon identified by its unique ID.
Request Headers
Path Parameters
id string Yes The unique identifier of the beacon (e.g., ICAO 24-bit hex address or SafeSky internal ID).
Example Request
curl 'https://public-api.safesky.app/v1/beacons/3423C3' \
Response
200 OK — Returns a single Beacon object (see Model Definition).
Example Response
  "id": "3423C3",
5. Search Beacons
Endpoint: GET /v1/beacons/search
Description:
Search for a beacon by call sign or aircraft ID. Useful for finding a specific aircraft when you know its identifier or call sign but not its current geographic location.
Request Headers
Query Parameters
call_sign string No The call sign to search for (e.g., IBE06CK).
aircraft_id string No The aircraft identifier to search for.
At least one of call_sign or aircraft_id must be provided.
Example Request — Search by Call Sign
curl 'https://public-api.safesky.app/v1/beacons/search?call_sign=IBE06CK' \
Example Request — Search by Aircraft ID
curl 'https://public-api.safesky.app/v1/beacons/search?aircraft_id=3423C3' \
Response
200 OK — Returns a Beacon object if found (see Model Definition).
Beacon Types Reference
The beacon_type field indicates the category of the aircraft. The following values are supported:
Value Description
UNKNOWN Unknown aircraft type
GLIDER Glider / sailplane
PARA_GLIDER Paraglider
HAND_GLIDER Hang glider
HELICOPTER Helicopter
UAV Unmanned Aerial Vehicle (drone)
PARACHUTE Parachutist / skydiver
MOTORPLANE General aviation motorised aircraft
JET Commercial jet / heavy aircraft
AIRSHIP Airship / blimp
BALLOON Balloon
GYROCOPTER Gyrocopter / autogyro
FLEX_WING_TRIKES Flex-wing trike / microlight
PARA_MOTOR Paramotor
THREE_AXES_LIGHT_PLANE 3-axis ultralight / light sport aircraft
PAV Personal Air Vehicle
MILITARY Military aircraft
STATIC_OBJECT Static object (e.g., obstacle)
Transponder Types Reference
The transponder_type field indicates the technology used to broadcast the position, or for advisory objects, identifies them as declared operation zones:
Value Description
ADS-BI SafeSky ADS-BI (smartphone-based)
ADS-B Standard ADS-B transponder
FLARM FLARM collision avoidance system
OGN Open Glider Network
MODE-S Mode S transponder (secondary surveillance radar)
ADVISORY Declared UAV operation area. The beacon is not a tracked position — parse the operation_area GeoJSON field to render the operational zone.
