3 - Getting Started
This guide shows how to quickly start using the SafeSky Public REST API to retrieve live traffic data.
Sandbox first: If you are testing your integration, replace
https://public-api.safesky.appwithhttps://sandbox-public-api.safesky.appand use your sandbox API key (ssk_test_...). The sandbox mirrors the production API but uses degraded traffic data and has no quota. See 5 - Environments & Platform Status
Prerequisites
- An API key from SafeSky (see Authentication)
- A tool to make HTTP requests (e.g.,
curl, Postman, or your preferred HTTP client)
Step 1 — Check API Health
Before making any data requests, verify that the API is reachable:
curl 'https://public-api.safesky.app/' \
Expected response:
UP
Step 2 — Retrieve Network Statistics
Get a quick overview of live activity across the SafeSky network:
Example response:
"timestamp": 1733412793,
"active": 12540,
"inactive": 430,
"grounded": 87,
"beacon_counts": 13057,
"transponder_types": [
{ "ADS-B": 6200 },
{ "ADS-BI": 4100 },
{ "FLARM": 1800 },
{ "OGN": 740 },
{ "MODE-S": 217 }
"beacon_types": [
{ "JET": 3200 },
{ "MOTORPLANE": 2100 },
{ "HELICOPTER": 980 },
{ "GLIDER": 870 },
{ "UAV": 430 }
Step 3 — Retrieve Live Traffic for a Viewport
Fetch all live aircraft visible within a geographic bounding box. The viewport parameter is formatted as lat_min,lng_min,lat_max,lng_max:
Example response:
"id": "3423C3",
"status": "AIRBORNE"
"id": "A1B2C3",
"latitude": 47.21354,
"longitude": 3.42719,
"beacon_type": "GLIDER",
"transponder_type": "FLARM",
"last_update": 1733412790,
"altitude": 1250,
"course": 310,
"ground_speed": 28,
"vertical_rate": 3,
"accuracy": 5,
That's it!
With just three requests you can:
- Verify the API is reachable and your key is valid
- Monitor live network activity across the SafeSky ecosystem
- Display real-time aircraft traffic on a map
To visualise the traffic returned by the API, open live.safesky.app (production) or sandbox-live.safesky.app (sandbox) in your browser.
