3 - Getting Started
This guide shows how to quickly start using the SafeSky Public REST API to retrieve live traffic data.
Sandbox first: If you are testing your integration, replace https://public-api.safesky.app with https://sandbox-public-api.safesky.app and use your sandbox API key (ssk_test_...). The sandbox mirrors the production API but uses simulateddegraded traffic data and has no quota. See Environments & Platform Status.
Prerequisites
  • An API key from SafeSky (see Authentication)
  • A tool to make HTTP requests (e.g., curl, Postman, or your preferred HTTP client)
Step 1 — Check API Health
Before making any data requests, verify that the API is reachable:
curl 'https://public-api.safesky.app/' \
Expected response:
UP
Step 2 — Retrieve Network Statistics
Get a quick overview of live activity across the SafeSky network:
Example response:
  "timestamp": 1733412793,
  "active": 12540,
  "inactive": 430,
  "grounded": 87,
  "beacon_counts": 13057,
  "transponder_types": [
    { "ADS-B": 6200 },
    { "ADS-BI": 4100 },
    { "FLARM": 1800 },
    { "OGN": 740 },
    { "MODE-S": 217 }
  "beacon_types": [
    { "JET": 3200 },
    { "MOTORPLANE": 2100 },
    { "HELICOPTER": 980 },
    { "GLIDER": 870 },
    { "UAV": 430 }
Step 3 — Retrieve Live Traffic for a Viewport
Fetch all live aircraft visible within a geographic bounding box. The viewport parameter is formatted as lat_min,lng_min,lat_max,lng_max:
Example response:
    "id": "3423C3",
    "status": "AIRBORNE"
    "id": "A1B2C3",
    "latitude": 47.21354,
    "longitude": 3.42719,
    "beacon_type": "GLIDER",
    "transponder_type": "FLARM",
    "last_update": 1733412790,
    "altitude": 1250,
    "course": 310,
    "ground_speed": 28,
    "vertical_rate": 3,
    "accuracy": 5,
That's it!
With just three requests you can:
  • Verify the API is reachable and your key is valid
  • Monitor live network activity across the SafeSky ecosystem
  • Display real-time aircraft traffic on a map
To visualise the traffic returned by the API, open live.safesky.app (production) or sandbox-live.safesky.app (sandbox) in your browser.
Continue reading to explore each API category in detail.
