What will you see?
SafeSky enables pilots to view the positions of fellow aviators, promoting seamless communication and reducing the need for constant radio calls.aviators.
SafeSky collects and displays traffic data from 30+ different protocols and sources, including ADS-B, FLARM, OGN, and partially Mode S. As such, using SafeSky can give you at least "30 times more" traffic information, including traffic such as paramotor, paragliders, trikes, ultra-light, general aviation and some drone traffic. Of course, if other pilots aren’t using any detection device, SafeSky, like any other system, will not be able to see them. It’s like driving a car: if you do not turn on your headlights at night you cannot be seen … or too late.
1. Radio protocols:
  • ADS-B
  • ADS-L
  • Asterix
  • Fanet
  • Flarm
  • Fly master
  • Flying Neurons
  • InReach
  • Microtrack
  • Mode S
  • Navigate
  • OGN tracker
  • Pilot Aware
  • SafeSky
  • Spider
  • Spot
  • XC-Guide
2. SafeSky App: More than 75 000 pilots in Europe, on a steady rise
  • Navigation software: EasyVFR and Air Navigation Pro software is natively integrated with SafeSky and provides thousands of additional pilots
  • Paramotor and paraglider portable hardware: SkyTraxx, Syride and FlyMaster are natively integrated with SafeSky, providing a large picture of free flight traffic
  • Paramotor and paraglider software: Gaggle, eVario, XCTrack, theFlightVario, WingIt, AirSports.no are natively integrated with SafeSky
While SafeSky provides significantly more flight traffic information than a single system or no system at all, it will not show everything. Visibility can be affected by factors like pilots not using a detection device, limited ground station coverage, poor internet, or mobile GPS quality. SafeSky is designed to supplement, not replace, eConspicuity equipment like ADS-B or FLARM receivers. Its main purpose is to remind and support pilots in flying VFR and adhering to ‘See and Avoid,’ not to substitute for tactical deconfliction decisions.
Get traffic alerts
Receive traffic from 30+ sources
