What will you see?
You will get the most complete trafficTraffic information servicefrom in-flight.many aircraft classes.
SafeSky collects and displays traffic data from 30+ different protocols and sources, including ADS-B, FLARM, OGN, and partially Mode S. As such, using SafeSky can give you at least "30 times more" traffic information, including exceptional traffic such as paramotorparamotor, paragliders, trikes, ultra-light, general aviation and some drone traffic. Of course, if other pilots aren’t using any detection device, SafeSky, like any other system, will not be able to see them. It’s like driving a car: if you do not turn on your headlights at night you cannot be seen … or too late.
1. Radio protocols:
  • ADS-B
  • ADS-L
  • Asterix
  • Fanet
  • Flarm
  • Fly master
  • Flying Neurons
  • InReach
  • Microtrack
  • Mode S
  • Navigate
  • OGN tracker
  • Pilot Aware
  • SafeSky
  • Spider
  • Spot
  • XC-Guide
2. SafeSky App: More than 7075 000 pilots in Europe, on a steady rise
  • Navigation software:  EasyVFR and  and Air Navigation Pro software is natively integrated with SafeSky and provides thousands of additional pilots
  • Paramotor and paraglider portable hardware:  SkyTraxx,  Syride and  and FlyMaster  are natively integrated with SafeSky, providing a large picture of free flight traffic
  • Paramotor and paraglider software: Gaggle,  eVario,  XCTrack,  theFlightVario,  WingIt, AirSports.no  are natively integrated with SafeSky
While it may not show everything, SafeSky shows invisible traffic compared to other collision avoidance systems andprovides significantly more airflight traffic information than a single system or no system at all, allit withoutwill anynot additionalshow hardwareeverything. Visibility can be affected by factors like pilots not using a detection device, limited ground station coverage, poor internet, or financialmobile cost. GPS quality. SafeSky is designed to supplement, not replace, eConspicuity equipment like ADS-B or FLARM receivers. Its main purpose is to remind and support pilots in flying VFR and adhering to ‘See and Avoid,’ not to substitute for tactical deconfliction decisions.
YouGet willtraffic be forewarned in case of a collision risk.alerts
Forewarned is forearmed.  If this traffic would come to close, you will get an an alert (visual or audible).
You will get the most interoperable in-flightReceive traffic informationfrom solution!30+ sources
SafeSky offers both a a Free and a PREMIUM plan. The Free Plan includes all safety features, including traffic information. The PREMIUM Plan offers added comfort and compatibility, particularly with navigation software and connectivity to your devices.
