STEP 5 - Create Your Aircraft and Take Off!
When you press "TAKE OFF", SafeSky will simply ask you for a quick piece of information to provide about your aircraft.
Fill in at least your Callsign and activate the Transponder to ON if you have one. This will enable the automatic identification of your hexadecimal code linked to your transponder through connected databases.
If your aircraft has a transponder, failing to provide the hexadecimal code will result in your aircraft being duplicated on SafeSky: once through SafeSky and once through the transponder. This will create a permanent alert during your flight.
