SafeSky on your phone
You can run SafeSky on your phone and separately use a tablet for your navigation software.
SafeSky on your tablet
Details on how to share traffic are explained in the "SafeSky in Detail / Traffic Sharing" chapter. The traffic sharing feature is available for PREMIUM users.
Using Only Your Phone
Here's how to proceed:
  3. Your traffic will be visible on your navigation map.
This is what your phone will display, using SkyDemon as the navigation software. SafeSky works in the background and shares the traffic with SkyDemon, which is then able to display the traffic on its maps.
Using only your tablet
    • SafeSky in the background and navigation software in full screen.
    • Split-screen mode, which provides comfort during the flight by combining SafeSky's radar alerts with the traffic display on your navigation map. Watch the video explaining this traffic integration set-up for more details.
Using Both Phone and Tablet
Option 1 - Phone as hotspot
Option 2 - Phone for SafeSky and Tablet for Navigation Software: In this case, your tablet should not have a SIM card. Traffic will be sent directly from SafeSky to your navigation software.
  1. Launch SafeSky on your phone and configure "Preferences / Traffic Sharing" to select your navigation software.
  2. Press "TAKE OFF."
  2. Appuyer sur DECOLLER.
