You have different options:
  • Using SafeSky and your navigation app on separate devices without traffic sharing
  • Using SafeSky and your navigation app on one single device without traffic sharing
  • Using SafeSky and your navigation app on separate devices with traffic sharing (PREMIUM only)
  • Using SafeSky and your navigation app on one single device with traffic sharing (PREMIUM only)
SafeSky on your phone
SafeSky on your tablet
Using only your phone
Here's how to proceed:
  1. Launch SafeSky, select your navigation software in the "Settings" and press "TAKE OFF."
  3. SafeSky traffic will be visible on your navigation map.
Using only your tablet
Using both phone and tablet
Option 1 - Phone as hotspot
  1. Launch SafeSky on your phone and configure "Settings / Traffic Sharing" to select your navigation software.
  2. Press "TAKE OFF."
