Activate MAYDAY - SAR (Search & Rescue)
If one or more of your fellow pilots (included in your SafeSky fellow pilots list - See the "Settings" chapter) is in flight, you can easily locate them on the map and send them pre-recorded messages if you wish.
Radar Screen vs Map Screen
