Stop the flight
By
Toggle pressing the map icon at the top right of the screen, you can switch to map mode. This view can give you a better awareness of the surrounding traffic (Situational Awareness). Similarly, in map mode, you will have the option to switch back to radar mode. Switching tobetween map mode doesand notradar stopmode the
of your position.
